trinh15596
How???
Hello everyone !!
I want to insert the "ClientServerDlg" first and "SetupTypeDlg" (in this order) in te "First Time Install", but when i try to insert one (using <Add Dialog>), the other dissapear... What i am doing wrong?
I'm using A.I. 11.18 bulid 62156
Thanks and regards from Tenerife, Canary Islands, Spain.
Trinh
Re: How???
Hello Trinh,
If you tried to add them on the same dialog hierarchy, the encountered behavior is correct.
However, once you expand the ClientServerDlg, you can add the SetupTypeDlg for each option that the user may select, Client or Server:
Dialog hierarchy.PNG (57.38 KiB) Viewed 3707 times
Please let me know if that helped, otherwise give us more details about your scenario.
