Hello Ken,
I'm not so sure why this happens. However, can you please double check you followed the next steps:
1. download and install the "jdk-8u171-macosx-x64.dmg" setup on a Mac OS machine
2. browse to "/Library/Java/JavaVirtualMachines/jdk1.8.0_171.jdk" on your Mac machine and copy the "jdk1.8.0_171.jdk" installation archive on your Windows machine
3. open Advanced Installer on your Windows machine
4. create a setup project (with "For Java" or higher project type) and go to "Builds" page
5. here add a new Mac Build (e.g. "BuildMacOS")
6. go to "Java Products" page and select the "Settings" tree node in the middle pane
7. in the top toolbar menu select the "Java Products" tab; here make sure you select your "BuildMacOS" build
8. in the "Java Settings" right pane click on the [Add JRE] button and browse to the "jdk1.8.0_171.jdk" installation archive copied on your Windows machine
9. save and build your project
Here is a screenshot with the Mac OS JRE bundled for your Mac OS build:
- screen.jpg (122.57 KiB) Viewed 11150 times
Hope this helped.
