leapold
Not delete database when application uninstall
How to add condition that special database file will not be deleted on the cleanup?
I would like to keep it (database.db) when the app will be removed.
The database location is Windows Volume->
( C:\ProgData\Test\Data\Test1\database.db)
I want add custom condition for Uninstall Cleanup process.
datadaa
Re: Not delete database when application uninstall
If you want to prevent a file from being removed during an uninstall of the application, you can go to its properties and select the "Do not overwrite existing file" option from the "Operations" tab.
Another method is to go to its related component from the "Organization" page and check the "Permanent" flag for it.
