ryjekpl
Custom dialog doesn't translate after adding new language.
EDIT:
I found what I done wrong. I don't use [ButtonText_Back] etc. in pt translations.
Recently I added Portuguese (pt_BR) language and my custom dialog (showing during product remove) doesn't translate at all, doesn't even translate buttons label.
Maintenance dialog in portuguese
Custom dialog with empty translations
Custom dialog in not default language
I have already five language in installer but they have been added before I created this dialog (if I remember correctly). There are translations in project because every other build-in dialog window is translated also it's working for other languages. Any idea how to fix this? Recreating dialog doesn't help.
Also could you tell me how to test other language than default in maintenance dialog? If I added selection of language at installation start I can change it's language but there is no such option for this in maintenance.
Piotrek
Re: Custom dialog doesn't translate after adding new language.
Hello Piotrek,
I'm glad you solved this.
When using the "Display language selection dialog" option you should get the setup running on maintenance mode in the same language as it was installed. However, please keep in mind that you should use the same "ProductCode" for all of your installation languages. You should just go to "Product Details" page -> "Product IDs" tab.
