kiranchauhan91
Prerequisites - Post install setup files do not install
We have existing installer using Advanced installer software. We have used Prerequisites installation using setup file path pointing to the .EXE file (http://www.somedomain.com/software1.1.exe). We wanted to change the download URL to something like this (http://www.somedomain.com/software.aspx). The ASPX page simply downloads the exe file. But when we do that, Advanced Installers simply opened the executable in Notepad instead of executing them. Advanced installer does not support file extensions other than EXE for prereqs?
Kiran Chauhan
Re: Prerequisites - Post install setup files do not install
Hello Kiran,
Please note that there might be a problem with how the Web Server is configured, as it may provide the Web Client with the wrong information. It may sent information to the Web Client to handle the requested file as a text MIME type, instead of an application MIME type.
In order to test this, you can manually copy the link into the Internet Explorer Web Browser and see if it is still treated like a text file, or if it is treated like an executable file.
If you have any further questions, let us know!
kiranchauhan91
Thank you for your reply. I checked download URL in the browser and it download EXE file. It returns proper MIME type. See Image below:
It we use same URL but with EXE path, it works. But when page is other than EXE then installer tries to open the aspx file using default program.
Any Idea?
Kiran Chauhan
Hello Kiran,
Can you please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate its settings? Also, please send us the .ASPX download URL by e-mail so we fully run a test on our side.
kiranchauhan91
I have sent you an email.
Kiran Chauhan
Hello Kiran,
Thank you for your sent sample, I have tested it and I have reproduced the problem. It looks like an issue in Advanced Installer, indeed. We will further investigate and we will update this thread as soon as we have a solution.
As a workaround, please use an URL which ends with your .EXE setup file name.
Thanks for your understanding.
kiranchauhan91
Do you know the timeline on releasing the fix? We have "advanced installer 11.4.1 build 58484" installed and not sure if that patch would be compatible with this version.
Kiran Chauhan
Hi Kiran,
Unfortunately, I do not know a timeline for releasing this fix. It is on our TODO list with a high priority.
We will update this thread as soon as it will be available.
Thanks for your understanding!
Hello Kiran,
Our development team further investigated and it seems that Advanced Installer gets the file name and its extension by parsing the URL string. So, that's why your .EXE file was opened with Notepad, because the file that was downloaded from that URL was actually "software.aspx", not "software.exe", that's why Windows did not know how to treat that file and opened it with a default program such as Notepad.
As a solution to this, you can go to "Prerequisites" page from the "Package Definition" group, click on your prerequisite, go to "Setup files", in "Main Setup File" and in "Folder" field type the following :
?yourSetupName.exe (e.g. software.exe, as we had it as an example above)
This field is used for our "Predefined Prerequisites" to specify a local download folder and an optional custom file name like this :
DIRECTORY?FILENAME
If the "?FILENAME" construction is missing, the download file name from the URL is used automatically.
If you have any further questions or doubts, don't hesitate to contact me and I'll gladly assist.
kiranchauhan91
It helped. Thank you for your help.
Kiran Chauhan
Hello Kiran,
I am glad I could help!
If you will ever need help, don't hesitate to contact us and we will gladly assist.
Hello Kiran,
This improvement has been added in Advanced Installer 17.3, released on July 29th, 2020.
