srikanth4sree
Unable to Update using Exe
older version of exe , app directory location in user specific folder. We got new requirement to change the app directory to ProgramFilesFolder.
For that i have made below change to AIP file.
Application Folder : [ProgramFilesFolder]\[Manufacturer]\[ProductName]
Download update in this folder : [ProgramFilesFolder][Manufacturer]\[ProductName]\updates\
Previous values are :
Application Folder : [LocalAppDataFolder]\[Manufacturer]\[ProductName]
Download update in this folder : [LocalAppDataFolder][Manufacturer]\[ProductName]\updates\
After creating new exe, i am installing new exe on top of old version, still app directory showing as LocalAppDataFolder.
I have un-install older version, after that installing newer version of exe , directory showing as ProgramFilesFolder.
also attached the project file and screen shot for reference.
please let me know what all the changes need to done, to install newer version on top of existing version.
base.aip
(118.61 KiB) Downloaded 520 times
Re: Unable to Update using Exe
Hello Srikanth,
You can see my reply here : viewtopic.php?f=5&t=35533#p99347
