mathiaso
Capital letters in customized dialogs
I am trying to get our product name to display with capital letters with a specific font that we have.
To do this I changed [ProductName] in dialog editors to MYPRODUCT (just as an example)
However, I am only getting the capital letters to work on a new dialog that we created. All other dialogs that were included with Advanced Installer will show Myproduct instead of MYPRODUCT.
Can anyone help with this?
Re: Capital letters in customized dialogs
I have tested your given scenario, but everything worked fine.
Can you please send us the .aip (project file) by e-mail at support at advancedinstaller dot com so we can investigate its settings? If you cannot share with us your project file, then you can try to isolate the behavior in a buildable sample (.aip + its referenced files) which we can build and test on our side.
