MLiss@Cetrus.com
Install succeeds but kernel driver does not install
I have an interesting problem... for two different clients where our installer ran... the installer failed to install the Kernel mode driver.
I have attached the install logs hoping you can shed some light on ANY thing that can point us as to why the driver failed to install.
AgentInstall_2.log
(200.79 KiB) Downloaded 393 times
AgentInstall.log
(202.67 KiB) Downloaded 351 times
Last edited by MLiss@Cetrus.com on Fri Jul 06, 2018 10:54 pm, edited 2 times in total.
MLiss@Cetrus.com
Re: Install succeeds but kernel driver does not install
Here is how I am installing
Hello Mike,
I am afraid I cannot find anything useful in the log file. Accordingly to the log file the "Driver_Install" custom action exit successfully and so the installation process.
Can you try to manually launch the Setupapi.dll -> InstallHinfSection function and see if the driver successfully installs on those machines?
MLiss@Cetrus.com
Daniel,
Thank you for your technical review of the log files - much appreciated.
I cannot, as these are client machines out of our office. (non technical people on the other end)
I will just have to chalk this one up as "mysterious failure" and move on.
Thanks again
Mike
You are welcome Mike.
