stevebroshar
XML file schema prompting
If you really want to make your XML file editor nice, you could leverage the XML schema to suggest keys and values to add. Currently, the editor is very free-form. When I add a key or value, there’s no hint as to what names are valid. But if I’m editing a config file in visual studio, it prompts me with options for valid keys/values. That is SO nice. You should do the same.
Re: XML file schema prompting
Thank you for your sharing with us your suggestion. I added it on our improvement list and hopefully it will be available in the future.
We will update this thread as soon as it will be available.
This improvement has been added in Advanced Installer 17.9, released on January 25th, 2021.
Return to “Feature Requests”
