Mikhail
Updater dialog customization
I am using Professional version of AI to create Java installer.
Is it possible to change standard icon on updater dialogues?
Best regards.
Mikhail.
Re: Updater dialog customization
Hello Mikhail,
Yes it is possible to change the updater icon. In order to achieve this, you can go to "Updater" page from the "Product Information" group and under "Display" tab, press on "File Icon" and choose the icon you wish to be displayed for your updater.
