acpowell
Issue trying to package AutoBid Apps
I have 3 apps that all give me the same issue. They seem to capture fine but as soon as I go to import I get the following error:
autobid error.PNG (21.93 KiB) Viewed 7623 times
I am not really sure where to go next, I have left everything on advanced installer at the defaults which has worked for almost everything else I have done. I am also doing this on a VM which is how I have done all my other apps.
Any help is appreciated.
Re: Issue trying to package AutoBid Apps
I am not sure why you encounter this behavior.
Can you please send us the .aip (project file) and the necessary resources to reproduce this behavior by e-mail at support at advancedinstaller dot com so we can investigate its settings and test it on our side ?
acpowell
Catalin wrote:Hello,
You want me to send you the entire project folder? I can defiantly send the aip file but I am not sure what you want out side of that.
In order to test this behavior, we need the .aip (project file) and the necessary resources. If you can not share with us the resources needed to reproduce this behavior, you can try to divest the project to the point where the issue still persists.
Also, I noticed that you are using an older version of Advanced Installer. Does this problem still persists when tested with a newer version ?
