Sakairg
Running installer "can't find file" error occurs
Hello, I made an installer that works, but there is one edge case where it doesn't... So the problem is, that I install app that works, then I release update. I update my application and app still works. Then I uninstall app via "Add or remove programs" (it's windows application.), then I delete app folders from %appdata% and Program Data folders. I download latest version of app and trying to install it and then this error occurs (see image). The thing is this scenario crashes on one PC, I've tried same scenario on two other PCs and everything worked perfectly. Not sure where is the problem... Registry on PC was not touched, so it should not make this problem. So I just taught that maybe installer is somehow corrupted...
If someone faced this problem or knows where it may come from, please tell me and I will investigate every possible solution to fix this...
Re: Running installer "can't find file" error occurs
I am not so sure why this happens. You can have a look on "Source file not found:" forum thread which exposes a similar issue with possible solutions.
