aweber
AI_PROCESS_STATE not available as an installer prop
I am trying to detect a running process using the custom action, and this apparently sets the "AI_PROCESS_STATE" property to one of two values.
That's fine (though limiting - why would you not be able to set a custom property so you can detect multiple processes?).
However, when I go back to add a custom Launch Condition, that property is not listed as an option to check. If this is a standardized property, shouldn't it be available in the "Select a Property" dialog? (Yes, maybe it's null or empty if the installer is not using it.)
Otherwise, I would have to define my own property, and that means I am required to give my property (AI's property) a value. But I don't want to give it my value, I want it to contain the custom action's value.
So if it's an AI defined property (it currently is), make it available for selection from the property choosers. If it's a custom property, then make it clear that even after using the custom action, you must go add a custom property with the specified name.
In any case, how do I actually use it right now? (v15.1)
Thanks.
aweber
Re: AI_PROCESS_STATE not available as an installer prop
ah, it's available via type-ahead, but not if you want to select it from the property dialog.
Currently this is our design implementation, but thank you for your suggestion. Maybe we will improve this in the future.
This is due to a current limitation in our "Edit Condition" dialog indeed. Our select a property list does not include this property too. We will fix this in a future version of Advanced Installer, thank you for bringing this to our attention.
In the meantime as a workaround you could simply use our autocomplete feature. Just start typing in the "Condition" field the property name and you will get a suggestion list.
If there is anything else we can help you with just let us know.
This was fixed in version 15.3 of Advanced Installer released on September 12th, 2018.
