gattausen
updater does not interactive with desktop from base user
good morning
i'm testing your solution but i've following problem:
i create my package with updater.exe set to:
pass an other administrative account (the name is admin)
with correct password.
set to act to interact with the desktop.
schedule at logon.
flag is NOT set run only if this user is logged on.
using updater.exe /checknow from user admin
i got my updater menu and i can work fine......
Instead if i log with a base user (no admin) i dont see updater menu
even if i set my updater with interaction with desktop and
user admin is set correctly.
Why ? I think updater has to run with admin account even if i log with base user !!!
thx
Max
gigi
Hi Max,
The updater runs (see "Task Manager") but the UI is not visible since it runs under different account. This is related to the Windows Scheduled Tasks behavior. The task will interact with the desktop of the user that you have specified in the "Account" tab of the "Edit Scheduled Task" dialog. Again, this is related to Windows Scheduled Tasks, even if you create the task manually in Windows you will get the same behavior.
Gigi
Gheorghe Rada
Advanced Installer Team
