jbraaten
Remove Icons from 'Quick Feature Select'
Is there a way to remove the icons from 'Quick Feature Select' or if you can't remove them, is there a way to change them?
(Attached is an image of what I mean)
Re: Remove Icons from 'Quick Feature Select'
I am afraid that it is not possible to change or delete the icons from the "Quick Feature Select".
If there is anything else I can help you with, let me know and I'll gladly assist!
