Following the screenshot in this post: viewtopic.php?f=2&t=35854, my MSI package is now installed but my configuration file "custom.inf" has not been applied during the installation process.
What am I missing here?
The "custom.inf" file has been added to "additional files" ... but still not applied.
In what regards the issue you had in your first thread, that most probably happens because some custom actions need to run elevated, otherwise they will fail. In order to avoid that, you can set the "Execution Time" as "When the system is being modified (deferred)" and under "Execution options", you can check the "Run under the LocalSystem account with full privileges (no impersonation)".
Can you please try the options presented above and let me know the results?
In what regards the issue you are facing in your second thread, I am not sure why that happens. In order for me to further investigate, can you please send me the .aip (project file) and the configuration file needed (the one you are using) by e-mail at support at advancedinstaller dot com?
