sonda
SQLServerConnectionDlg property from time to time is despairing
I have added SQL server connectionDlg, and go to add some folders and files and save aip. Close advanced installer and next day when i try to open the project .aip file its throw error like on picture:
i was not sure what is happening and i have build the project, and building was ok, but when i start the exe file i have received this error that was more clear where to search the problem:
when i opnned SQLserverconnectionDlg i see that the control is missing:
I was thinking that i have deleted somehow, and i have started new project and also happend on the new .aip file. After a wile same happens and control was again missing, and also ond new project.
Any suggestion what can i be doing wrong, why this happens from time to time.
Re: SQLServerConnectionDlg property from time to time is despairing
We apologize for the delayed reply.
We tested the scenario but unfortunately cannot replicate the issue. Can you please try to manually uninstall the Advanced Installer application and then download and install it again?
If the behavior still persists then please send us by email to support at advancedinstaller dot com your AIP (project file) so we can further investigate it. Also if you could isolate the issue in a more detailed step by step test case or pattern this will be very useful too.
