rafizan46
Invalid MSI identifier string [.ontrol.Text.NewDialog_4#ProductLog].
Help !!! .. i can't open my project this morning. I got error Invalid MSI identifier string [.ontrol.Text.NewDialog_4#ProductLog]. What should i do? :(
rafizan46
Re: Invalid MSI identifier string [.ontrol.Text.NewDialog_4#ProductLog].
Problem solved. Thanks.. I figure out something wrong with this row
<ROW Dialog_="NewDialog_4" Control="ProductLogo" Type="Bitmap" X="17" Y="6" Width="99" Height="102" Attributes="1" Text="[NextCancelButtons]" Order="600" MsiKey="NewDialog_4#ProductLogo"/>
Thank you for your follow up on this.
If same issue will occur again then please try to see if you could isolate the issue in a small test case or pattern which generates this glitch. This will be very useful for us.
rafizan46
Hi, this morning the same problem occur again. I dont know what actually cause it. The row suddenly become this
<ROW Dialog_="NewDialog_4" Control="ProductLogo" Type="Bitmap" X="185" Y="8" Width="99" Height="102" Attributes="1" Text="[swordf]" Order="1000"/>
Unfortunately I really cannot say what is happening.
Did you configure any settings within the Advanced Installer with UI application for the "ProductLogo" control of your "NewDialog_4" dialog from "Dialogs" page of your setup project? Maybe you can manage to find a pattern.
Also, please make sure the XML content of your AIP setup project is not edited by any third party tool (like a version control tool during a merge/check-in operation).
