andyeaust
Feature based Prerequisites not installing on silent install
Hello Community,
we have a package with some feature based prerequisites.
When we run the Setup.exe in Full-UI, all prerequisites are installing properly. We think that it worked on older Release of AI. At the Moment we use AI 15.3.
When we use Silent install NO feature based prerequisites are installed.
We read the FAQ https://www.advancedinstaller.com/user- ... uestion122 and test the available Solutions but Nothing helped.
We made a new test-project, add the prerequisites with no other files and no special Installation behaviors. It's the same. It runs in FullUI but not silent.
We test what happened when we remove the install command lines for Silent (no UI) of the feature based prerequisite. Then we get an error at Installation:
We look at https://www.advancedinstaller.com/user- ... uestion134
Because of this we check the download/extraction Folder of the prerequsite, it's the default "[AppDataFolder][|Manufacturer]\[|ProductName]\prerequisites"
Also we check the build extraction Location "[AppDataFolder][|Manufacturer]\[|ProductName] [|ProductVersion]\install"
We also make a msi log and check it with "Wilogutl.exe" but can't find any errors.
We ca send you a complete test Project, but it's About 175MB.
In Atachement you get a test AIP
PS: It's the same if we install only "build in" feature based prerequsites like c++ 2010 Runtime x86.
Thanks for your Help,
Andreas
andyeaust
Re: Feature based Prerequisites not installing on silent install
I check something else:
i found this article viewtopic.php?f=2&t=34927
With AI 15.3 it's not working with the /q
I made a additional Test-Project with 15.01:
The prerequesites are installing with the /q silent Parameter.
But: If i add there a prerequiste with "Additional Files" None of the prerequisites are installing… mhhh..
I remove this prerequisite, it works.
I opened the 15.01 Project with 15.3 and make a build:
No prerequisites are installed
I think there must be something wrong with silent Installation in the 15.3 and something with additional files in the 15.01
Hello Andreas,
I am not sure why this happens.
In order for me to further investigate this, can you please send us a copy of your .AIP file (project file) that reproduces this behavior and a download link for the setups you are trying to add as "Feature-Based" prerequisites by e-mail at support at advancedinstaller dot com?
Kind regards,
Hello Andreas,
I have tested your scenario and indeed, you are right, the "Feature-Based" prerequisites are not installed when the main package is installed silently. This seems to be an issue in what regards Advanced Installer.
A fix will be available in a future version of Advanced Installer.
andyeaust
Hello Catalin,
thanks for your Reply.
We have the Problem, that our main Installer not working at the Moment because of this Is there a chance to Downgrade our AIP Project to 14.9?
Because we have a important bugfix delivery to our customers and we have no backup :cry: of the old aip.
Regards
Andreas
Hello Andreas,
Unfortunately, it is not possible to downgrade your AIP project to 14.9.
It is considered a best practice to always have your files backed up and Advanced Installer also automatically creates a backup when you build your project using a newer version.
andyeaust
OK,
i see the AIP backup Files from the older Versions. But when i open one backupfile with the older Version i get the Message:
"This Project (Fragment) was editetd with a newer Version of Advanced Installer (15.3) and cannot be loaded"
What data i have to backup to can go down to an older release.
Aditionaly: What time we have to plan for a new AdvancedInstaller Release which fix the Problem.
Hello Andreas,
That error occurs when the backup .aip project was also edited / re-built with the 15.3 version of Advanced Installer. I am afraid there is no way you can open your project with 14.9 version now, since the backup file was re-built using a newer version.
In what regards this, unfortunately, I can not give you any estimation, but I will update this thread as soon as a fix will be available.
This was fixed in version 15.4 of Advanced Installer released on October 17, 2018.
EmmanuelV
Hi Advanced Installer team!
I'm facing the same situation described by andyeaust. We have a Setup.exe with feature-based prerequisite:
2022-05-17 113539.png (10.45 KiB) Viewed 9986 times
It works fine in UI mode but fails in silent mode ( /exenoui /qn). The install fails because some custom actions need the prerequisites. I tried to remove the custom action using the prerequisites. The silent install was ok but all the prerequisites were installed AFTER the main install.
Moving the prerequisites to "Pre-Install" is not an option for us, because some install cases don' need all the prerequisites.
We currently use AdvInst 16.5. I also tried with the last version (19.4) : same behavior :(
Any help would be appreciated.
Emmanuel
Hello Emmanuel and welcome to our forums,
Please note that the behavior you encounter is the normal one.
Basically, feature-based prerequisites are installed on a dialog event, more precisely, when the user presses the "Install" button, right before the installation of your main package starts. The reason fro this is the Windows Installer limitation which does not allow two installation processes to happen at the same time.
Why do I receive the "Another installation is already in progress" message?
However, when your main package is installed silently, then no UI is displayed. With that being said, the only solution here is to install those prerequisites as "post-install".
This is the reason why, when you launch your main setup silently, the prerequisites are actually installed after.
I'm afraid the only solution here would be moving the prerequisites to the "pre-install" section.
EmmanuelV
Thank you for your answer Catalin.
You are always welcome, Emmanuel!
