docasio1
Shortcut does not go to specified directory
I configured a shortcut to the executable to go into a subdirectory but it never goes there . an uninstall shortcut does go there properly.
I am testing on a windows 10 pro machine
ScreenShot 232 2018-09-28 10.25.png (225.98 KiB) Viewed 1942 times
Re: Shortcut does not go to specified directory
We apologize for the delayed reply.
I am not so sure why this happens. Can you please make sure you create the related shortcut subdirectory under "Start Menu \ Programs" folder in "Files and Folders" page of your setup project?
If this is still of no help, then please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
