mythox
VSTS SetVersion before Build
Is possible to set version of AIP file before build it?
Re: VSTS SetVersion before Build
Yes, this is possible by using our "SetVersion" command line option in the "Command Line Arguments" section of your Advanced installer build task.
mythox
I was settinged as /SetVersion instead of as SetVersion without '/'
Now is working :))
Thanks a lot.
You are always welcome.
