janisito
Create self-signed certificate on IIS
I would like the functionality to make the installer create a self-signed certificate on IIS.
Thanks!
Re: Create self-signed certificate on IIS
Thank you for your suggestion. We already have this feature on our todo list and hopefully it will be available in the future.
As soon as the feature is released we will update this thread.
janisito
Great! Thanks!
You are always welcome.
sc.spms.test
Daniel wrote: Tue Oct 30, 2018 8:31 am You are always welcome.
Where can I find the self-signed certificate on IIS feature you said way back 2018?
Unfortunately, this improvement has not yet been implemented.
I have increased its priority and hopefully it will be implemented in a future version of Advanced Installer.
sc.spms.test
Catalin wrote: Thu Jun 20, 2019 10:12 am Hello and welcome to Advanced Installer forums,
Good day
Is there a way where I can create a self-signed certificate? I'm making an installer for a web application and I need a https for the bindings. During installation, it always prompts an error regarding SSL certificate.
Thank you.
Unfortunately, we do not have predefined support for creating self-signed certificates (you can not create a self-signed certificate from within Advanced Installer).
However, you can create your own certificate and then use the "Install PFX certificate from the package" option from "IIS" page --> "Bindings/SSL" --> under "SSL Certificate (HTTPS Bindings)" section.
For instance, you can create the self-signed certificate using IIS manager.
Eternal21
It would be a nice feature. In the meantime the best you can do is a custom powershell action using New-SelfSignedCertificate cmdlet.
Thank you for your followup on this and for sharing your solution with us.
From what I can see, this might be under our development team's radar, as it has the "work_in_progress" label.
I will update this thread as soon as this improvement will be implemented in Advanced Installer.
This improvement has been added in version 18.5 of Advanced Installer, released on July 27th, 2021.
janisito
Thank you!
You are always welcome, Jan!
adartois
I have license pro with lastest version.
i am not finding entry for creating a self signed certificate on website install ...
Where is this options ?
Thank you.
Please note that the option is not available under IIS, it is actually available as a Custom Actions.
With that being said, you need to go to "Custom Actions" page and add the respective custom action.
"Generate and install self signed certificate"
Return to “Feature Requests”
