sonda
Using path variables and building from cli
I have created path variables in my project, according to this: https://www.advancedinstaller.com/user- ... ables.html,now i can use operations and save to, and i have my .apf file. After this how can i build my project with path variables from command line?
AdvancedInstaller.com /loadpathvars var.apf /build MyProject.aip
Re: Using path variables and building from cli
You can build your project via the command line by using the following lines:
AdvancedInstaller.com /loadpathvars <path_to_vars>
AdvancedInstaller.com /build <path_to_project>
sonda
If i run this command AdvancedInstaller.com /build the installer is builded, but if i run two command like you suggested every time when i run:
it says that can not acquire floating license and build fails, not sure what to do? I know the server is ok and i can acquire licence since if i run advanced installer from guid i can build project
I am not sure why this happens. This may happen if the "Advanced Installer License Server" service had a "Stopped" state at the time you were trying to load the path variables into your project.
Could you please try this again and, if it fails, check if the above specified service is up and running ("Started")?
Also, you may find some useful information about this in the Event Viewer. To do so, please open a Run Window (Win+R buttons combination), type "eventvwr", hit "Ok" and then go to "Windows Logs" --> "Application".
Kind regards,
