claudenoel
Log string not recorded from C# Custom Action
I created a C# custom action which works fine. However, I want to record some data in the log file. I tried 2 methods:
session.Log("What I want to show in the log file");
session.Message(InstallMessage.Info, new Record { FormatString = "What I want to show in the log file" });
None of these work. I can see my C# function called from the log file but not my string. What am I doing wrong?
Even session.Message(InstallMessage.Warning, new Record { FormatString = "What I want to show in the log file" }); is not working.
Re: Log string not recorded from C# Custom Action
Hello Claude,
Is you custom action added as a custom action without sequence (triggered from an UI control)? If that is the case, please keep in mind that the "session.Log" method does not log anything when triggered from an UI control (dialog control).
With that being said, if you want to write a specific event into a log file, all you have to do is to add your C# custom action with sequence.
Kind regards,
claudenoel
Oh thanks. Yes it was without sequence for testing purposes. It works fine when used with sequence. :)
You're always welcome, Claude.
