Lord123
failed to create priconfig.xml
I have tried thousands of ways and I have not managed to find the solution to this error.
someone help me please.
see the images..
Re: failed to create priconfig.xml
Can you please send us the .aip (project file) to support at advancedinstaller dot com so we can test and investigate its settings? Also, please open Advanced Installer, go to "File" menu -> "Settings" -> "External Tools" and let us know the full path set in the "MakePri.exe" field.
As a side note I have observed that you are using AI 15.5 version. This version of Advanced Installer is still in the production phase and was not officially released by now. I assume you got a beta version from one of my colleagues from support team. Can you please confirm this too?
Lord123
Hello Daniel. Yes, that is correct. I got it with a support, I thank them very much for the service they provide.
But that is not the case. I tried with the versions 14.9, 15.2, 15.4 and this one, and in all the same thing happens with the priconfig.xml or resource.pri error.
Do you want the aip to pass by here or do you want me to send it to some mail?
Please send it by email. And also, please open Advanced Installer, go to "File" menu -> "Settings" -> "External Tools" and let us know the full path set in the "MakePri.exe" field.
