Nashath
service runig issue
am not able to install the service created through advanced installer while action type is start once i remove the start i can instll but its not runig
service error.JPG (217.7 KiB) Viewed 5647 times
Re: service runig issue
Hi Nashath and welcome to Advanced Installer forums,
Can you please let us know if you are able to manually install and start the service outside the installer? Does everything work as expected?
If Yes, please send us a download link so that we can test your case on our end. Please strip down your project to a basic size containing only the dll and other resources absolutely necessary to reproduce the issue. Make sure this sample project is buildable and send it to support at advanced installer dot com so we can build it and study the issue.
