sonda
PkgMgr.exe has been deprecated
Today i recieve this error when i want to install my software, any reason what can be wrong?
sonda
Re: PkgMgr.exe has been deprecated
In this case this error was because windows have updates to be installed, today i have installed updates, and all old installers that throw errors now are working ok. So this ticked now can be closed.
sorry for this post
Thank you for your follow up on this.
Certainly your feedback will be useful for future customers facing similar scenarios.
Sephiroth.Wang
Hi Team,
Any solution for this PkgMgr.exe, our applications cannot install on part of operation system (Window 10 2016 LTSB)
Unfortunately we never got the root cause of such errors.
Can you consistently replicate this error on multiple machines with Window 10 2016 LTSB? If so, could you please forward us the .AIP (project file) and a verbose log of the installation by email to support at advancedinstaller dot com so we can investigate them?
