Abdul-Rahman
Reset Button In CustomizeDlg
I know that if I put one of the features in a CustomizeDlg to not install and then press reset the features will be reset to what they were set to before the modifications ,but if I press next then go back then press reset they won't go back to what they were before pressing next ,it is as if when you press next the default settings are now what was set exactly before pressing next ,can I undo that where only the default settings of the features tree at the launch of the installer will happen when you press the reset button at anytime ?
Thanks ,
Abdul.
Re: Reset Button In CustomizeDlg
Hello Abdul,
First of all, I apologize for the delayed reply.
In what regards your request, I am afraid that it is not possible. What is happening when you press the "Next" button is the intended behavior (the value for the state of the feature is saved), that being the reason why when you press "Back" and try to reset the value, it does not reset to the state that the feature had before pressing the "Next" button.
Kind regards,
Emmanuel
I have the same issue (AI v16.5). Is there a workaround to reset the state of the features when I press "Back" to return on CustomizeDlg dialog box?
Thank you for your help,
Emmanuel
Hello Emmanuel,
If you go to "Dialogs" page --> "CustomizeDlg" --> select the "Reset" button you will notice that it has the "Reset control properties to default values" event attached to it.
After the next button is pressed, the control holding the states of the features will have a different value, e.g.:
FeatureA --> to be installed locally
FeatureB --> to be installed locally
The user changes to:
FeatureB --> to NOT be installed locally
If the user pressed "Next", the control will be stored with its' new value. If you then click on "Back", the default value will be the one where FeatureB is not installed.
By default, all the features from your project are to be installed locally (unless you change it). If you want to reset all the features when the "Back" button is pressed, you could reset all the feature's states from the modified state to the default one (to be installed locally).
To do so, you could add, on the "CustomizeDlg", an "Init Event" as it follows:
Event: Install one or more features locally
Argument: ALL
Condition: leave default
This way, when the "Back" button is pressed and the "CustomizeDlg" is initialized, the event will execute.
Emmanuel
Hello Catalin,
Thank you for your answer. I applied your instructions but the result is the same. :(
Do you know another workaround to enforce reset on all the feature states actions?
Hello Emmanuel,
This is really strange, as I have tested this myself and it worked as expected on my end.
You have probably misconfigured something.
Could you please create a sample project that reproduces the issue on your end and forward it to me to further investigate it?
Emmanuel
As requested, here is a sample.aip that reproduce this behaviour.
I probably missed something...
Thank you
sample.aip
(28.94 KiB) Downloaded 2147 times
Hello Emmanuel,
Thank you for the provided project.
From what I can see, you did not quite implement the steps I have given above at all.
Below you can find a screenshot of the "Init Event" I have mentioned in my previous mail that did not exist in the sample project (I have added it myself):
Please read my previous thread again and try to implement the steps.
Also, please let me know if anything is not clear enough.
Emmanuel
Thank you for our answer and sorry for the misunderstanding. Actually, I already applied your instructions on my main aip file. I applied this to the sample.aip (in attachment) but it still don't work...
In the log file I found : ADDLOCAL = Feature1,Microsoft.NET5.0.4,Node.js (Feature2 was unselected)
Expected : ADDLOCAL = Feature1,Microsoft.NET5.0.4
I noticed that when I add "Install one or more features locally" on CustomizeDlg this be applied to all the controls of the dialog box, even the "Next" button. Is that normal?
sample.aip
(30.02 KiB) Downloaded 1948 times
Hello Emmanuel,
On the "CustomizeDlg" dialog, "Next" button, you do have an "Install one or more features locally" that points to your Node.JS prerequisite, therefore ADDLOCAL containing it is normal here, as per definition of ADDLOCAL:
The value of the ADDLOCAL property is a list of features that are delimited by commas, and are to be installed locally.
Could you please give me some more details (exemplify) about what you are trying to achieve here?
The event should only be added to the selected button. This is usually the "Next" button or the event is added as an "Init Event" (triggered by the "Next" button of the previous dialog)
Emmanuel
It works fine now. I just omitted to apply this to the prerequisites features (uninstalled by default).
Thank you again for your help, next time I'll try to be clearer :D
Emmanuel
You are always welcome, Emmanuel!
I am glad to hear everything works as expected now. :D
Return to “Feature Requests”
