blackpanda
Don't show extract folder of SQLSETUP.exe
I added a prerequisite for SQLEXP2017 with silent simple install to my installer. It's good. When I ran my installer, it showed a dialog to prompt user to select an extract location for SQLEXP, how can I hide this dialog? We only want to show the progress in the UI without any actions from users.
Thank you.
Re: Don't show extract folder of SQLSETUP.exe
In order to achieve what you want, you can pass the following parameters in the "Install Command Lines" fields in Advanced Installer.
/x:LocationToExtract
Kind regards,
blackpanda
I tried to add a command as you suggested
The installer still show this screen.
Any comments?
That is a strange behavior. I have tested this just now and it worked as expected (the user is not prompted to choose the location).
Can you please try to manually install the SQL Server (maybe on a clean virtual machine) using the exact command line as you have used in the "Install Command Lines" field? If that does not work manually, it can not work in Advanced Installer either.
Also, for your reference, here is the command line I have used:
"C:\Users\Catalin\Downloads\SQLEXPR_x64_ENU.exe" /x:C:\ExtractionFolder /qs /ACTION=INSTALL /FEATURES=SQL /INSTANCENAME=MSSQLSERVER /SQLSVCACCOUNT="<ComputerName(OR DomainName)\UserName" /SQLSVCPASSWORD="<password>" /SQLSYSADMINACCOUNTS="ComputerName(OR DomainName)\UserName" /AGTSVCACCOUNT="NT AUTHORITY\Network Service" /SQLSVCINSTANTFILEINIT="True" /IACCEPTSQLSERVERLICENSETERMS
The above command line can be used to manually install SQL Server. In Advanced Installer, you should only pass the command line starting with "/x:....".
Kind regards,
blackpanda
Thank you for your reply. I found the problem.
1st:
C:\Windows\Temp seems inaccessible and will cause unexpected behavior.
I changed it to C:\Temp and it's OK
2nd:
Advanced Installer seems only accept this command '/qs' when working with /x. I tried '/q=false /qs=true' and '/qs=true' those can run manually install SQL Server but Advanced Installer always show the Prompt screen.
The correct one must be /x:C:\Temp /qs
You are always welcome. I am glad I could help.
I have tested this with "/q" command as well, and it worked as expected. I have to admit that I did not test it with the command lines you have specified above. I will have a look into that soon and I will let you know the results.
