fmh1959
Launch file (and wait for finish)
Hi
We have a number of installers which basically installs a service with a corresponding database.
For the database installation we use SqlPackage.exe which takes a dacpac file and a number of parameters.
The way we have done this so far is that we launch a file InstallDB.cmd with the relevant parameters from the installer.
The problem is that this process sometimes takes a while and the installer is not waiting on this process.
If I add a "pause" in the end of the cmd file - the installer just continues .
So how do we do this in general - having some kind of external process where we need to wait for the finish?
I have attached the picture of our custom action which is calling the InstallDB.cmd - we DO NOT understand the checkmark "Wait for custom action to finish before proceding". What is the function of this if not waiting :-)
Best Regards
Re: Launch file (and wait for finish)
First of all, I apologize for the delayed reply, but we were quite busy lately.
In what regards your problem, I am not sure why this happens. Could you please send me a copy of the AIP file by e-mail at support at advancedinstaller dot com so I can further investigate this?
digocesar
Hi.
A similar issue that I had was solved at release 15.5.
https://www.advancedinstaller.com/relea ... hancements
Please see if this release solves your problem.
Thank you for contributing to our forum, Rodrigo. It is highly appreciated.
And yes, I suspect this is the case for him as well.
Kind regards,
