sumit1
Hyperlink for pre-install UI dialog
Hi
we are added hyperlink in pre-install UI dialog add url and property name but when we are click on this hyperlink specific file does not open.
URL: file://[AI_SETUPINTELLISYSENVIRONMENT_SQLSERVE]
Property Name:HYPERLINK_1_PROP_1_2
Hyperlink Name: Hyperlink_1
This URL pattern not worked.PDF file available in temp folder
Re: Hyperlink for pre-install UI dialog
Unlike Advanced Installer's regular files or resources, "Temporary Files" are copied on the target machine at the beginning of the installation and are deleted at the end of it, ensuring you have access to them throughout the entire install process.
Temporary Files are copied during the CostFinalize standard action, at the beginning of the setup and removed during the InstallFinalize standard action.
Now, Pre-Install prerequisites are additional packages that are installed before the MSI is launched. The pre-install prerequisite and the main package are two different processes.
In your scenario, you are trying to access a file that extracted to the temporary folder before it is actually extracted, leading in you being unable to open the file.
In order to make this work, simply move your hyperlink control on a dialog from your main package (e.g. "WelcomeDlg" from under the "FIrst Time Install").
The solution above should work, because the "CostFinalize" standard action takes place before the "WelcomeDlg" is displayed, so, when you will try to access the PDF file, it will be present on the machine (in the %temp% folder)
Kind regards,
sumit1
Thank you Catalin.
But is there any way/alternate solutions to add hyperlink in Pre-Install prerequisites.
Because in prerequisite we want to add hyperlinks.
All FIrst Time Install hyperlinks work fine there is no any issues.
Hello Sumit,
I am afraid that it is not possible to achieve what you want, because your PDF file is extracted way after you are trying to launch it.
However, I think there may be a workaround for this. For instance, you can convert your PDF file to a RTF file and then use a "Scrollable" control on your dialog. After adding the "Scrollable" control to your dialog, select it and, on the right pane, under "Display" --> "RTF File" field, pick your RTF file by pressing the "..." button.
sumit1
Thank you Catalin.
You are always welcome, Sumit.
I am glad I could help.
Kind regards,
Return to “Feature Requests”
