don_ucw
Setting an EXEs compatability settings
Is there anyway we can set compatability settings for an EXE once it is installed? Specifically we need to set the high DPI settings to *not* override.
thanks!
Re: Setting an EXEs compatability settings
We do not have built in support for this, but you can try to add your EXE app in "Program Files" folder and the create the "Layers" registry as explained in "Overriding High DPI Scaling from the Command Line" thread.
Hope this helped.
don_ucw
Thanks for the help - we'll investigate
You are always welcome.
