alejandro2992
Capture of Package
How to capture the update of an existing package.
Lord123
Re: Capture of Package
very good question.
you mean that the AI allows you to modify a msix by adding the files manually.
but it does not allow the capture of an update which is very necessary sometimes when we want to capture an updated program.
The question is
The advaced intaller is it possible to capture a program by taking an existing msix package like the msix packig tool does?
@alejandro2992: To capture the update of an existing product you can try to make use of our "Repackager" tool. Just start our Repackager tool and launch the product update process.
@Lord123: "The advaced intaller is it possible to capture a program by taking an existing msix package like the msix packig tool does?"
I am not sure I fully understood your question. Can you please give us more details about this?
Return to “Feature Requests”
