sumit1
prerequisite selector
Hi
We want to show messages on the basis of prerequisite selectors check boxes.Following are the details
1) In prerequisite selector dialog showing all added prerequisite with action Skip or Install.Skip means its already install and Install means needs to be install
2) I want to Show messages on the basis of prerequisite selector checks box
e.g: a) In attachment image SQL server is already installed in that case static text/Text display sql server is already installed.If there is text box present then hide this text box on the installation status
b) ODBC driver needs to be install so static text display/print You need to install ODBC driver etc.
In that project prerequisite selector is visible false i.e not showing to end user
Can you please provides all steps for this.
Thank you
Re: prerequisite selector
Hello Sumit,
Unfortunately, I am afraid that this is not possible. The "Prerequisite Selector" control is seen as a whole and you can not access its elements (i.e. the checkboxes that are assigned to each prerequisite).
However, you can try to schedule your prerequisites as "Feature-Based" prerequisites instead of "Pre-Install", create your own custom dialog and then you can try to condition the visibility of your static texts based on what the user has chosen. For more information about this, you can have a look on our "How to conditionally install a prerequisite based on the user selection?" article which I think you may find useful as a starting point.
Kind regards,
sumit1
Thank You Catalin
You are always welcome, Sumit.
Glad I could help.
Kind regards,
aswinsrinivasan02
@Catalin So just to understand this better, if I want to display a dialog based on if a particular pre-requisite is selected or not, is not possible in Advanced Installer today?
It is possible to achieve that, but only for "Feature-based"/"Post-install" prerequisites.
To do so, you can show your dialog only if a specific feature will be installed. Whether the feature will be installed or not can be decided in the "PrerequisitesDlg" dialog.
Here would be the steps to achieve the above:
- add a feature-based prerequisite to your project
- add the "PrerequisiteDlg" dialog
- right click on your dialog --> "Show only if"
- under "Predefined Conditions", select the desired condition, e.g.: "Feature will be installed locally. The feature is not reinstalled"
- you will then be prompted to select the feature. Here, select the feature that is created automatically for your "feature-based" prerequisite.
aswinsrinivasan02
Thanks Catalin. Will try this out sometime :)
You are always welcome! :)
Return to “Feature Requests”
