khaybet
Please wait while windows configures
Hi Support,
Can you please advise on the following issues files attached
Could Not Create Key.PNG (8.4 KiB) Viewed 4967 times
Re: Please wait while windows configures
I am not so sure why this happens. Can you consistently replicate this on multiple machines? If so, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Thank you for your sent files.
It seems this error appears because you have configured your setup project to deploy and install a "COMPONENTS\Configuration" registry key directly under the HKLM hive (not sure why). Please keep in mind this registry key path is not accepted by the operating system. You should not create any registry key under HKLM hive root.
So, can you please open your setup project in Advanced Installer, go to "Registry" page, expand the "HKEY_LOCAL_MACHINE" hive, right click on the "COMPONENTS" key and delete it? Then rebuild your setup project and test it again.
Hope this helped.
khaybet
Thanks Daniel,
I will give this a try and let you know how it goes
You are welcome.
