dean_goddard
Unable to launch a MSI file as a custom action
(Preferace: I apologise if this is already answered by the search function of this forum is very limited and frustrating.)
I'm trying to run a Crystal Reports runtime (MSI) file, to kick off after the main application has been installed, but so far it just doesn't work. I have Version 14.5.2 Professional build 83143 on Windows 10 (just doing another update now). I've tried a few things, including executing the MSI file from the APPDIR working directory, or directly (APPDIR\CRRuntime_blah.msi), and even tried MSI.exe -U "APPDIR\CRRuntime_blah.msi". So far nothing fires it off.
I wouldn't have thought it would be this difficult. It would be nice if Advanced Installer, had a means to build a 'TEST' version of the installer, that was able to message box any warnings/errors directly to the user, live as they occur during the installation.
In the meantime I think I came across a means of logging the install output, so I'll update my version and try that and update this topic with what I find.
Re: Unable to launch a MSI file as a custom action
I apologize for the problems that you have encountered with our search function. However, we do have two searching ways:
- One of them is this:
which I would not advise using.
- And the other one is:
which I would advise using.
In what regards your main issue here, since you want to install it at the end of your main setup installation, have you tried adding it as a "Post-Install" prerequisite?
Post-Install prerequisites are prerequisites which are launched after your main installation. They are also handled by the installation user interface.
Kind regards,
dean_goddard
Ah. Thanks Catalin. That's exactly what I'm after. I'll give that a go now, and post back with any news.
You are always welcome.
Glad I could help.
Kind regards,
dean_goddard
Just letting you know that the prerequisite worked well.
Thanks again.
You're always welcome.
