m.qayyum
CLI taking too much time
Hi, why it's taking too much time(44 hours) to build a project from cli? Resulting setup size is less than 100mb.
https://imghostr.com/TwK22ZMt
Re: CLI taking too much time
I am not sure why that happens. I have just tested this now and the total build time was 7 seconds for an AIP that creates a 100mb setup:
In order for me to have a better view about this, could you please send me your AIP file by e-mail at support at advancedinstaller dot com?
Also, does the build process takes as long when done from UI as it takes when done from the CLI?
m.qayyum
Hmm, I'm using on rdp, that can be an issue? I will update you with the info from UI.
I have tested this once again using the Remote Desktop Protocol, but the result was the same. The build time was around 7 seconds for a 100MB resulted setup.
In order for me to further investigate this, could you please send me a buildable sample project which reproduces this issue? You can either attach it here or send it by e-mail at support at advancedinstaller dot com.
Kind regards,
