sonda
Advanced Installer search and replace and UTF8
I have some file in installer that i want to edit. The file can contain different characters mixed languages, in our example Cyrillic. I have said the file to be craeated with utf-8, but when i open file i have only squares in place where i should see Cyrillic text. I have included images and test aip. How can i avoid this when editing file. Something i'm doing wrong but i don't know wath.
how it looks after installing
test-utf.aip
(14.75 KiB) Downloaded 297 times
here is demo aip file
Regards
Re: Advanced Installer search and replace and UTF8
Hello Sonda,
First of all, thanks for the sent sample project.
Could you please try the following and let me know the results:
- Go to "Builds" page
- under "Database Encoding", please select the "UTF-8 encoding (support Unicode characters to be displayed)" radio button.
sonda
Thanks, it's works. I have seen this setting but i was mislead that this have something with db server ... and i have not tried...
Thanks you very much.
Regards
You are always welcome, Sonda.
Glad I could help.
