swapnilmusale
Facing Issue while connection licence server through VPN
Hi Team,
Facing Issue while connection license server through VPN, can someone help me with Issue?
Swapnil
Re: Facing Issue while connection licence server through VPN
Hello Swapnil and welcome to our forums,
Can you please give me some more details about the issue you are encountering?
Do you get any error message? If yes, could you please tell me which error you are getting?
Kind regards,
swapnilmusale
Please find the attachment for error.
Hello Swapnil,
Thanks for the provided screenshot. This error message may be given by the fact that you do not have a floating seat available. In order to check this, please open your browser and type the following:
http://<host_name>:<port_number>/admin
where:
- <host_name> is the name of the machine on which the license server is registered.
- <port_number> is the port used by the license server.
The above command should list your floating seat(s) and whether or not they are "free" or "in use".
Kind regards,
