BillM
'File -> Open' file browser shows wrong file dates
When I browse for a specific AIP file, it shows File Creation date for the file instead of Last Modified. For example, I made edits today and saved it. When I look in Explorer, it correctly shows the file having a timestamp of today. When I click File - Open in Advanced Installer, it shows a very incorrect timestamp, sometime in 2017 when the file was first created. When in that File->Open window I right-click and select Properties, it shows the correct timestamp. See image.
New Bitmap Image.png (176.24 KiB) Viewed 3358 times
Re: 'File -> Open' file browser shows wrong file dates
Hello Bill,
The timestamp is correct. Please keep in mind that the "Date" metadata represents the date where the file was created. If you wish to see the date when the project was modified, you can simply add the "Date modified" metadata:
BillM
Yes, thank you for that. I did find this quite surprising since the default Windows Explorer behaviour is to show the Last Modified date, not File Creation date.
You are always welcome, Bill.
Glad I could help.
Kind regards,
