apajovejohn
Creating AppPool with different properties
Hi folks,
My installer creates a website and associated app pool. I allow the user to specify either local system OR a user account for the app pool to run under.
This leads to be needing to create the app pool with either the default identity, OR an identity with account details.
I imagined that all I'd need to do is add two app pools to the installer with a condition to select the correct one, but I cannot add two app pools with the same name, so I'm not sure what the best approach is.
Anyone got any suggestions of how to proceed?
Re: Creating AppPool with different properties
Indeed, you can not use the same name for two "Application Pools". However, there is a little trick you can use in order to achieve that:
- Please go to "Install Parameters" page and create a new property and, as the property value, you can have the name you want to give to the "Application Pool".
- Now go to "IIS" page and create two "Application Pools", one having as name the earlier created property and one having the normal name.
apajovejohn
That looks like just the ticket! Not sure I would ever have come up with that myself!
Many thanks
John
You are always welcome, John.
Glad I could help.
