ipollock
IIS - Set Common Headers
Good morning,
We are currently using Advanced Installer 12.7.2.
I am looking for a way to set the IIS - Common HTTP Response Headers for website A to disable Internet Explorer caching web content from the IIS Server side. Client side controls are handled differently and we don't need to cover that here.
There is a way to set this on an indivual level for each application and virtual directory - it works but if you have a lot of these then it takes a while to complete the task. I'm trying to cut this task time down by setting it at the web site level. This can be done quite easily when the web site has been installed. I don't see any control available in the installer application to enable it at this higher level.
1. Is there a control i can use?
2. is there another way i can achieve this.
Many thanks,
Ian
Re: IIS - Set Common Headers
Hi Ian,
If you want to set some headers for a website, you can use its "HTTP Response Headers" tab and add the desired headers there. Doesn't that work for you?
ipollock
Hi Eusebiu,
The HTTP Response Headers are set up on a per application or virtual directory level and only affects that application or virtual directory. This means that i would have to do and later manage lots of changes (In this case 22 changes to implement).
What I would like to do is set the 'Common Header' which is found at the Site level, for example 'Default Web Site' and this would affect all
applications and all virtual directories within the site with just one change.
This control would be found in IIS Manager at the site level, HTTP Response Headers and in the actions pane 'Set Common Headers'.
I can't seem to find the control for this in Advanced Installer.
Ian
Hi Ian,
Indeed, we do not have predefined options for setting the common headers, however you can achieve this through the "Custom Properties" support. For this, you can go in the "Custom Properties" tab of your website and set the desired properties as shown in attached image.
If you need more details, just let me know.
IIS Set Custom Headers.png (41.12 KiB) Viewed 5862 times
ipollock
Excellent, i hadn't tried that as it's not available on our production system yet (12.7.2) so that will help me push for a change/update to newer version.
Thanks again for your help.
Ian
You're welcome Ian. Glad to help.
