Borgas
Propertybased settings for IIS SSL (cert)
Is there a way to configure SSL for IIS by property?
I need to be able to set type of SSL certifiakt i like to use when i run the setup. I need to toggle between "Use existing server certificate" and "Install PFX certificate chosen at run time"
Re: Propertybased settings for IIS SSL (cert)
Unfortunately we do not have built-in support for this.
As a workaround solution you can try to duplicate your web site entry in "IIS" page and configure one web site to use the former SSL option and the other to use the latter SSL option. Then you can conditionally install the web site using an installer property.
Hope this helped.
