jusher
Problem with new version 15.5.7
I did an auto update from 15.5.1 to 15.5.7.
Now a 32 bit version of my project has ODBC problems (not responding)
I did the following: -
Used previous version of MSI which installed without a problem.
Used the same aip file and rebuilt with version 15.5.7.
This just hangs when using TestODBCConnection custom action.
The parameters I enter are the same so there should not be a problem.
The 64 bit msi works fine under the new version.
Any idea what could be wrong here? I am now going to go back to the previous version of AI
that worked 15.5.1.
John
jusher
Re: Problem with new version 15.5.7
Sorry I meant 15.5.1 and 15.7
jusher
Went back to 15.5.1 and everything works as it should.
My conclusion can only be that something has changed in AI around TestODBCConnection for 32 bit projects.
I will attach the aips for your perusal.
John
SchemaInstallationTool32.aip
Updated works in 15.5.1 not 15,7
(106.11 KiB) Downloaded 794 times
SchemaInstallationTool321551.aip
Original works in 15.5.1 not 15.7
(106.1 KiB) Downloaded 878 times
Hello John,
Thank you for the sent .aip files, but unfortunately I can not open them due to some missing repository items. Could please also send me these:
AMIParametersDlg_0_1.aip
BTSCustomizeDlg.aip
PrimaryServerConnectionDlg_0_1.aip
PrimaryServerConnectionDlg_0_1_3.aip
SITPrimaryServerConnectionDlg.aip
SecondaryServerConnectionDlg_0_1.aip
so I can open the sent aip files and investigate their settings?
jusher
You already have all of the dialogs I use. Ask Dan for them please. I sent them all before.
John
jusher
I also noticed this: -
viewtopic.php?f=2&t=32277#p102608
It is slightly different in that I am not returned a timeout error but I guess it may be relevant.
Any luck getting dlgs?
John
jusher
Here are the dialogs you wanted.
AIDialogs.zip
Dialogs for 32 bit problem on 15.7
(814.8 KiB) Downloaded 867 times
AIDialogs.zip
John
Hello John,
First of all, thanks for the provided files.
I have further investigated your .aip files and I could not notice anything wrong with that. I have also tried to reproduce this in a sample project, but I was not able to do so.
In order for me to continue with the investigation, could you please forward, by e-mail at support at advancedinstaller dot com, the following:
- the log file for the installation of the setup built with 15.5.1
- the log file for the installation of the setup built with 15.7 (where the ODBC Connection TImeout occurs)
- a download link for the setup built with 15.5.1
- a download link for the setup built with 15.7
jusher
As I said I did not get a Timeout Error the installation just hangs i.e. does nothing.
The box where it is attempting ODBC connection is displayed on the page.
John
Hello John,
It seems that I misunderstood your scenario. I apologize for that.
However, I will still need the above files so I can continue with the investigation.
