pankaj.garg29
Parse Error at line 1 , column 0 (code not well formed), invalid token
Hello Support,
We are facing an unusual problem wile opening .aip file. We have created installer project and using it since many years. now we have migrate our server and move the file on different server.
Now we are trying to open .aip file then it is giving "Parse Error at line 1 , column 0 (code not well formed), invalid token" error.
Please see attached,
We are using 11.5.1 version of advanced installler and tried the latest version as well. But there is no success.
This is on high priority as we need to release our software to client.
Please help!
Thanks & Regards
Pankaj
problem screenshot
problem screenshot
aip issue.png (40.72 KiB) Viewed 2601 times
Re: Parse Error at line 1 , column 0 (code not well formed), invalid token
Hi Pankaj,
It seems that your project got corrupted somehow, but I cannot say how this happened. Can you please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate it?
