Dural
How to get an exist value from Registry and use it?
Please how is it possible to get a value from a allready exist RegistryValue?
In Inno Setup it's very easy. For example, with this code, I can get a string from the Registry and put it in variable "DefaultDirName"
DefaultDirName={reg:HKLM\SOFTWARE\MyCompany\MySpecialPath,MyAppDir|{pf}\MyAppName}
I need to to this in AI for setting "Application folder" (in "Install Parameters") like this:
Application folder = [HKLM\SOFTWARE\MyCompany\MySpecialPath] OR IF SpecialPath ISN'T EXIST = [[ProgramFilesFolder]\[ProductName]]
And also I need a error message with stop the installation, if another key in registry ins't exist.
Like this: IF [HKLM\ABC\RegistryValue]<>'123' SHOW Message "Sorry, Installation not possible! Please open www.moreinformations123.com for details!"
(How) is this possible with AI Professional?
Re: How to get an exist value from Registry and use it?
What you want to achieve can be done through our predefined support for "Searches" and "Custom Actions".
Here is a step-by-step process which you can follow in order to achieve what you want:
- go to "Search" page and create a new search (right click under "Target Computer" --> "New Search").
- now right click on your search --> "Add search location" --> "Registry".
- now configure the search as per your needs. For instance, for a registry key-value pair like this:
the search could be configured like this:
- now that we have created and configured the search, it is time to create a MessageBox custom action which will display your desired message. To do so, you can proceed as it follows:
- go to "Custom Actions" page and add a "Display message box" custom action.
- after doing so, simply condition it based on the earlier created search.
Dural
Thank you very much!
It works fine, but 've two last questions:
First, how can I set the alternate destination-path, if the registryValue is empty?
What I mean is the end of this pseudo-code:
Variable = [HKLM\SOFTWARE\MyCompany\MySpecialPath] OR IF SpecialPath ISN'T EXIST = [ProgramFilesFolder]\[ProductName]
And the last question, how to cancel/abort the installation if the MessageBox was displayed and the user click cancel?
I Know the condition > BTN_PRESSED="IDNO", so this is not my problem, I'm looking for something like go to ExitDialog or ExitInstaller...?
I am afraid that this is not possible by using our predefined support for searches. This is happening because the Windows Installer does not guarantee the searches order, so a new search should not use the result of another search. As an alternate solution, you can create your own custom action (e.g. PowerShell, VBS) that will search for the respective registry entries.
This can easily be done by placing a custom action after your message box that will return an exit code equal to 3. Windows Installer interprets any exit code different than "0" as unsuccessful, so your setup will end. This can be achieve as it follows:
- after your "MessageBox" custom action, add a "PowerShellScriptInline" custom action with the following content:
exit 3
- condition your custom action with the following condition:
((VersionNT > 501) OR (VersionNT = 501 AND ServicePackLevel >= 2)) AND BTN_PRESSED="IDCANCEL"
from under the "Execution Stage Condition" section.
