mehdi_m
Windows 10 64 bits setup fail installation prematurely
I run a software compatible windows 10 64 bits, and on a client PC same configuration, Setup ends up prematurely, first time in hundreds of installations..
Windows event show nothing, I tried to build the same content setup using another installer (old one) and it works fine, component registration etc, works perfect. So I wonder what to do? I will try to install it after creating another user account maybe I saw that UAC was inactive, probably some action on the client pc, I put it back on even if I knew it won't change anything?
Any clue or suggestions?
Re: Windows 10 64 bits setup fail installation prematurely
Hi and welcome to our forums.
In order to get more details about this problem, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
