janisito
Quick launch shortcut not visible
My installer sets a quick launch shortcut to my application. It works on all OSes except on Windows Server 2019. Why is this? Is this a bug in AI or does it need to be created differently?
Thanks!
Regards
Jan
Re: Quick launch shortcut not visible
Hello Jan,
I have tested this and indeed, you are right, the shortcut is not pinned to the taskbar after the installation on a Windows Server 2019.
We will further investigate this on our end and as soon as I will come to a conclusion, I will let you know.
janisito
Any idea if this will be fixed in a coming AI release?
Regards
Jan
Hello Jan,
We have further investigated this but we were unable to find the root cause of this problem.
Unfortunately, I am afraid I can not tell, as for this moment, if this will be fixed in the coming AI release, since we were not able to find the root cause of this.
However, I will update this thread as soon as we find the root cause of this and as soon as there will be a fix available. Thank you for your understanding.
