faizanmanzoor123
How to create Custom Connection with Attach DB Script
HI
how I create Custom connection with Attach DB Script. When I run the installer without script its works fine and ODBC Driver also created in Menu.
but when I attached DB Script file , the installer show error on the first screen. Error screen is attached.
Thanks In Advanced.
Re: How to create Custom Connection with Attach DB Script
Hello Fainzur and welcome to our forums,
This behavior is strange, because the related ODBC error is usually thrown when, on the target machine, the ODBC driver you are specifying in your SQL Connection parameters is not installed.
In order for me to further investigate this, could you please send me a copy of your .AIP file by e-mail at support at advancedinstaller dot com?
I looked over your project and I noticed that the name of the SQL driver that you specified in the custom connection does not seem to be correct. To make sure that the driver you specified there is present on your test machine you can follow the instruction from the "ODBC Connection error" thread.
