Hello Abhinay,
In order to achieve this, you can enable the Major Upgrade for your project. A major upgrade is essentially the removal of an older product which is replaced by a newer product. In Advanced Installer the upgrades can be configured from the
"Upgrades" page.
A major upgrade is enabled by increasing the "Version" of your application (e.g. from 1.0.0 --> 1.0.1) (
"Product Details" page). After doing so, when you will navigate between the pages (e.g. select another page), you will be prompted with the following message:
- PC.PNG (10.08 KiB) Viewed 2519 times
There, you need to press
"Generate new" in order to generate a new ProductCode for your project. For more information about ProductCode, you can have a look on our
"Product Identification (ProductCode and UpgradeCode)" article.
